Main Lug Only Subpanels - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 01:59 PM   #1
Can you put bolt on breakers in a main lug only subpanel?
tmklosky is offline   Reply With Quote
Old 05-21-2012, 02:01 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If its a panel that accepts bolt on breakers.
You are going to have to be much clearer in your question/situation. Are you asking if there is a way to have a breaker feed a mail lug panel?
Old 05-21-2012, 02:29 PM   #3
Rewards Points: 49
Sub panel
Just a quick question on this topic. How bout the ground and neutral wires coming from the circuits? Do they go on the same lug or do they have to be separated? Sorry to bud in...
jambud is offline   Reply With Quote
Old 05-21-2012, 02:35 PM   #4
k_buz's Avatar
It would be better if you stated a new thread, but to answer your question, it would depend on if this was a sub panel or a main panel.
The Following User Says Thank You to k_buz For This Useful Post:
Speedy Petey (05-21-2012)
Old 05-21-2012, 05:40 PM   #5
Master Electrician
Rewards Points: 3,778
If you are talking about a main breaker it would depend on whether or not the panel is field convertible to accept a main breaker.
brric is online now   Reply With Quote
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
main lug or main breaker kenmore Electrical 14 06-18-2011 12:13 PM
where to put main vent hohadcr Plumbing 3 03-09-2010 08:32 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
