Main Lug Location - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 01:42 PM   #1
Main Lug Location
In the attached drawing I'm showing a mounting pedestal for a main lug from which to run a feeder to the house. To the left of the main lug is a 200 amp disconnect which is mounted on the utility pole. I'm not showing the meter but it is before the disconnect. About 18" of the pedestal is in the ground. I'm planning to run conduit and 2/0 copper from the disconnect to the main lug as shown, which is above ground. Does this look ok? I need a ground, i.e., four wires from disconnect to main lug, correct, and I do not bond neutral to ground at the main lug, correct?
Believer is offline   Reply With Quote
Old 07-14-2011, 01:56 PM   #2
Master Electrician
Rewards Points: 3,760
IMO the panel is located in a separate structure. If so you need a main breaker, a four wire feed and ground rods.
brric is online now   Reply With Quote
Old 07-14-2011, 08:12 PM   #3
I guess I could mount the main lug on the utility pole. I need to run two feeders so I have to get two circuit breakers after the disconnect. What purpose does another 200 amp main breaker serve?
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
Murray main lug center - what type of tandem breaker? cl or ncl? plove79 Electrical 4 09-01-2010 09:08 PM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 11:32 PM
New location for main panel Itsdanf Electrical 106 04-13-2010 08:12 PM
Replace Main Beam in different location? jrdamien Carpentry 5 01-10-2009 02:13 PM
