Main Lug Hot Wire Connector - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 05:58 PM   #1
Rewards Points: 248
main lug hot wire connector
A main lug has 2 spaces for 4 circuits. There are two places to connect the two phases of hot wire to. If I only have one hot wire available can I create a connector between the two locations where you are supposed to connect hot wires in the main lug? Is that safe or is that a big no-no?
The one hot wire available will never have more than 30A and the main lug is rated at 60A so don't worry about overloading anything.
jackwashere is offline   Reply With Quote
Old 11-15-2012, 06:07 PM   #2
Rewards Points: 332
Is this for a subpanel?
sgip2000 is offline   Reply With Quote
Old 11-15-2012, 06:41 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
You would have to splice them and not use the lug for 2 wires.
Old 11-15-2012, 07:14 PM   #4
Rewards Points: 248
exactamundo
Old 11-15-2012, 07:14 PM   #5
Rewards Points: 248
by splice you mean outside the box?
what is the difference between doing that and connecting them inside the box?
Old 11-15-2012, 07:20 PM   #6
jbfan's Avatar
Rewards Points: 478
Splice them inside the box.
The lugs are rated for 1 wire only.
Old 11-16-2012, 12:32 AM   #7
Rewards Points: 332
Since your subpanel will be on only one leg, be sure to balance your load across both legs.
clamp connector for a single wire (ground) amakarevic Electrical 5 05-16-2012 10:02 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
burnt wire connector... kemerick Electrical 4 02-12-2009 08:49 PM
Wire for main panels scrayzee21 Electrical 3 10-18-2008 12:35 PM
Which wire from the main breaker to the A/C condenser? slwalsh HVAC 2 10-15-2008 01:33 PM
