-   -   main lug hot wire connector (http://www.diychatroom.com/f18/main-lug-hot-wire-connector-163459/)
jackwashere 11-15-2012 06:58 PM
A main lug has 2 spaces for 4 circuits. There are two places to connect the two phases of hot wire to. If I only have one hot wire available can I create a connector between the two locations where you are supposed to connect hot wires in the main lug? Is that safe or is that a big no-no?
The one hot wire available will never have more than 30A and the main lug is rated at 60A so don't worry about overloading anything.
sgip2000 11-15-2012 07:07 PM
Is this for a subpanel?
jbfan 11-15-2012 07:41 PM
You would have to splice them and not use the lug for 2 wires.
jackwashere 11-15-2012 08:14 PM
exactamundo
by splice you mean outside the box?
what is the difference between doing that and connecting them inside the box?
jbfan 11-15-2012 08:20 PM
Splice them inside the box.
The lugs are rated for 1 wire only.
sgip2000 11-16-2012 01:32 AM
Since your subpanel will be on only one leg, be sure to balance your load across both legs.
