Main Lug Between Main Panel And Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 08:26 PM   #1
Main Lug between main panel and sub panel
Is this better than splicing?
MisterSteve is offline   Reply With Quote
Old 02-22-2012, 08:46 PM   #2
Julius793's Avatar
On sunday afternoons
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-22-2012, 08:50 PM   #3
I'll do it any afternoon if it is up to code. Does it need to have a main breaker pull on it?
Old 02-22-2012, 08:56 PM   #4
Julius793's Avatar
My post was sarcastic because honestly I have no clue what you are asking. How about you start over and explain what you are doing and what you want to know.
Old 02-22-2012, 09:15 PM   #5
Well, I am trying to get power to my detached garage about 80' away from my main panel. There is a piece of #2 AL SE-R in my crawl space fed from a 100 amp breaker in the main. Rather than tearing up the walls to get a full run to the garage, I would like to connect to this SE-R, which is what it was intended for. It is long enough to feed outside to the wall into a panel or junction box. So, my question is, can I use an outdoor main lug as a "junction"???
Old 02-22-2012, 09:50 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Still a little confusing, generally when we use the term main lug in residential we are talking about a main lug panel. So is that what your suggesting ? Or are you just meaning some kind of JB that has distribution lugs in it so that the splicing will be better and much more professional looking than say split bolts or big wire nuts.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-22-2012, 09:57 PM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I think what he is talking about is an outdoor rated 100amp disconnect box with a 100 amp breaker and just using that for splicing instead of a junction box and splices.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-22-2012, 10:03 PM   #8
Hi Stubbie,
Thanks for the inquiry! You seem to be paying some attention to my posts and probably are just as confused as i am at this point. I picked up an outdoor main lug for my "junction" instead of a junction box for various reasons but mainly convenience. To better clarify this is how I am planning to get my garage powered- 200amp main in house with 100amp breaker on #2 SE-R to 100amp outdoor main lug on the other side of the same wall, #2 USE-2 from main lug to 100 amp sub panel in garage. I am wondering if the lug is supposed to have a main breaker on it or not to be up to code???
Old 02-22-2012, 10:06 PM   #9
That's what I'm thinking I should have bought.
I bought a main lug and 70 amp 2 pole as the "main" breaker in it.
I will have the garage line connected to the 70 amp 2 pole in the lug so isnt that the same as a main anyways?
Old 02-22-2012, 10:07 PM   #10
rrolleston's Avatar
Can you post a picture of what you bought?
Old 02-22-2012, 10:09 PM   #11
heres a link.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Old 02-22-2012, 10:14 PM   #12
rrolleston's Avatar
Will you be putting this in your crawl space or outside?
Old 02-22-2012, 10:15 PM   #13
Outside.
Old 02-22-2012, 10:22 PM   #14
I just remember the man at the permit office telling me that if i have more than 6 circuits then the box needs a main breaker in it. But if the lug can't have more than 6 circuits then IT does not need a main breaker, right? But it is between a main panel and a sub.....so now I'm confused. Again. The reason I chose this lug box was because I thought maybe Ill add a circuit or two for some deck lighting or something someday.
Old 02-22-2012, 10:25 PM   #15
rrolleston's Avatar
As long as the inspector will allow it and it can support a 70 amp branch breaker it sounds like a decent idea.
