Old 10-03-2012, 12:57 AM   #16
Main load center grounding question.
Originally Posted by jbfan View Post
How many wires are you going to use?
I see 20 open screws on the right side!
There are just enough spaces on the right side for what I currently need without even adding more circuits.
There are several spots on the right bus that are for larger cables and a 12-14 ga wire won't fit tightly in them.
I have several circuits that were combined due to the limitations of the old panel. I am separating them as well.
For example, the kitchen counter outlets are wired on the same circuit as the well pump. I am putting the pump on its own circuit.
sgip2000 is offline   Reply With Quote
Old 10-03-2012, 05:54 AM   #17
Licensed Electrician
k_buz's Avatar
I would double/triple check that. Every well pump I have run across has been 240V and that wouldn't do well for kitchen counter recepts.
Location...Location...Location
Old 10-03-2012, 06:22 AM   #18
Electrician
Ground bars come in many different lengths. You can buy one that fits above the main breaker. This would remove the need to wire nut all those grounds. Screw it to the box and it's considered compliant, but I'm a little OCD so I'd run a little scrap wire to the neutral buss. The label on the door will have listed a maximum number of circuits. If you put in tandem breakers, you have to stop at the circuit maximum. If you're required to put in Arc Fault breakers, they each require a full space.
Glennsparky is offline   Reply With Quote
Old 10-03-2012, 12:45 PM   #19
They are indeed wired together. The well pump was "tapped" into the kitchen line via a JB. I will be removing the well pump from the JB and running a new line for it directly to the panel.
The pump can do 240 or 120 and is currently wired for 120. Since this is just for irrigation, I will likely leave it for 120.
Question on grounding main lug service rizzoa13 Electrical 38 06-22-2012 04:25 PM
Expanding load center capacity in barn mn1247 Electrical 8 09-13-2011 09:24 AM
New Main Panel Ground Question atmironov Electrical 29 06-27-2011 04:36 PM
Grounding from Junction Box too Main tlj Electrical 5 10-25-2009 01:48 AM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 08:48 PM
