Main House Breaker Keeps Tripping - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-21-2008, 12:57 PM   #16
Originally Posted by elkangorito View Post
I believe that now might be the time to conduct both continuity & insulation resistance tests on the suspect circuit. Unfortunately, this will require the use correct equipment or an electrician with the correct equipment.
That's a good call, but my main concern is to have this short circuit taken care of. Although, I'm hoping it doesn't boil down to me having to do that.
cosmicmah is offline   Reply With Quote
Old 01-21-2008, 01:01 PM   #17
Once fried, twice shy.
elkangorito's Avatar
The abovementioned tests will definitely find any problems in the circuit & you will not need to rip anything apart to conduct the tests. Also, the more often a breaker trips under short circuit conditions, the more it deteriorates. As a general rule, I replace all breakers that have tripped under these conditions.
I would suggest isolating the circuit until more testing has been carried out.
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
Old 01-21-2008, 03:08 PM   #18
I don't think there are other circuits upstream as everything else works ok.
You need to determine this. Test EVERYTHING.
I'll do some more troubleshooting, but I'm running out of options...
If the circuit is as simple as you describe it sould be simple. Remove both outlets from the wiring. Disconnect all conductors.
Problem is MOST likely in one of the two recep boxes. Sometimes when they strip the 3 wire cable they slice the insulation . Look for damage/burn marks.
Is the cable at the panel the same exact type as at the recep box?
I'd lose the metal extensions. They cause more fires than they prevent. Use plastic if necessary.
220/221 is offline   Reply With Quote
Old 01-21-2008, 06:18 PM   #19
Res Ipsa Loquitur
At first I was thinking of shorts due to metal box clamps- Since plastic boxes were used, staples shorting the cable external to the box could also be a possibility.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-21-2008, 11:19 PM   #20
Ok... I've repaired the problem. Here's what I did...
Pulled the wires out of the breaker and flipped them on. Tested that there was 120v. Flipped them off and noticed that there was still ~98-100v. Kinda odd. The other 15a had ~50v going through still in the "off" position. I bought new breakers and tested everything before turning them on. I'm glad it all works.
I was definitely thinking the worse.
Thanks to everyone for their suggestions, opinions and help.
Old 01-22-2008, 12:36 AM   #21
The breaker is NOT the problem.
Crap!
Never say never.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
