#1 |
Main grounding electrode wire to panel
Hi guys,
I'm finishing up installing my new panel and I have a question about the ground wires. I have a main ground wire from the water pipe, another from the new ground plate I installed as well as one from the gas line. Can these all be tied together with split bolts along the way or do they all have to terminate in the panel? As for inside the panel, the Square-D one I have has one lug connection in the top section screwed to the back of the panel, and it also has a connection right beside the main service neutral. The note on the panel says something about "service ground connection if required" or something similar (I don't have it on hand). Can the ground from the water pipe connect to this, since the neutral and grounds are intermixed anyway? I can take a pic later if need be. Thanks. |
#2 |
Solutions (handyman)
My understanding is that only one main ground is required. The more the merrier but as long as the ground is "grounded" you should be okay.
#3 |
Our local inspector (and code now I think) require any upgraded service to have a supplemental ground (rod, plate, etc) as well as to bond the gas line as well. I've installed a new panel and meter and am re-routing the original ground wire as well as adding the other 2. I'm just curious on the best way attach them all.
#4 |
I would run a ground wire direct from the panel to the ground plate (or ground rod) and use splice bolts to tie on the gas pipe and the water pipe connecting ground wires.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
| Display Modes | |
| Garage Wiring issues | jimmyfloyd | Electrical | 20 | 06-08-2009 03:57 PM |
| Adding ground bar to main panel | WoodworkerDave | Electrical | 6 | 09-27-2008 05:52 PM |
| Nuetral from feeder cable to main panel question? | TW Lucas | Electrical | 14 | 05-08-2008 12:33 PM |
| main lug vs main breaker for sub panel | diyll | Electrical | 1 | 01-17-2008 09:18 PM |
| Anyone want to take a shot at why #6 to attach antenna ground to breaker? | Piedmont | Electrical | 44 | 01-08-2008 05:11 PM |
