Main Circuit Breaker's Screws Hot Even With Breaker Off? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 02:23 PM   #1
Rewards Points: 83
Main circuit breaker's screws hot even with breaker off?
My panel looked like a hairball that a cat threw up, so I rewired it the other day. Labeled the hot wires with their circuit numbers on masking tape, unscrewed everything, and put it all back in an organized manner. Replaced a few breakers that were a different manufacturer than the panel while I was at it.
My system has a main breaker and no disconnect outside at the meter. I knew turning off the main would only turn off power to the hot bus bars, that the line coming in would still be hot.
I treated the screws on the main breaker the whole time as if they were hot, being extremely careful not to let anything touch them. Went fine, had no problems. (Was also wearing rubber soled shoes standing on a rubber mat, and took my ring off.)
Did I need to do this, or are main breakers made so that their screws just clamp down the wire internally but aren't hot themselves? I could so easily see a wire slipping and hitting one of those screws if someone isn't overly paranoid about them.
Seems to me like there's no benefit of having the screw itself hot, and that they could/should engineer at least the main so it wouldn't be.
darlingm is offline   Reply With Quote
Old 01-14-2012, 02:26 PM   #2
Rewards Points: 6,652
Hope your life insurance policy is paid for. This is a good post of what is wrong in so many ways, when working in a live panel.
Old 01-14-2012, 02:28 PM   #3
Rewards Points: 83
Boy, if I screwed up, I'm glad I made it through it. I'd love to know what I did wrong, though.
Old 01-14-2012, 02:35 PM   #4
Working on a hot panel, without pulling the meter.
Old 01-14-2012, 02:40 PM   #5
Rewards Points: 83
I'm confused. I really thought that when replacing breakers or adding new circuits that turning off the main did the trick, without having the meter pulled -- as long as you aren't re-wiring the main or doing anything with the wires going to the meter.
EDIT: So many guides that I've seen say when working with circuits, you have to turn main off or have meter pulled, but not both.
Old 01-14-2012, 02:47 PM   #6
jproffer's Avatar
Rewards Points: 702
Any time there is a chance, however remote it may be, of touching one of the hot conductors coming in or (as you asked about) the screws holding them in, it's a good idea to disconnect the next place upstream from that.
Or a more general rule...
Any time there is a chance, however remote it may be, of touching whatever you're working on, it's a good idea to disconnect the next place upstream from that.
You got lucky. I've done it too so I won't jump ya too bad...but I shouldn't have. And you shouldn't have either.
You lived through it, so all is well....but next time....
BTW, before 100 people disagree with me :
If I was pulling in a new circuit or just moving one or two things...I wouldn't mess with the meter. If I had a "hairball that a cat threw up" and I was re-sorting everything...have it pulled.
jproffer is online now   Reply With Quote
Old 01-14-2012, 02:56 PM   #7
MarginallyQualified
Rewards Points: 2,464
this will be a technical term soon
Old 01-14-2012, 04:54 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
A homeowner should never, ever, never pull the meter!
Taking of the ring was a good step, but the mat and shoes had no effect.
The Following User Says Thank You to jbfan For This Useful Post:
frenchelectrican (01-15-2012)
Old 01-14-2012, 06:24 PM   #9
joed's Avatar
Rewards Points: 11,576
Agree. You did it correct in my opinion. In Canada the main breaker is in a separate section with its own cover. Turn off the main and everything you see is safe.
As long as you stay clear of the main supply lines coming into the main breaker you are safe.
The Following User Says Thank You to joed For This Useful Post:
Old 01-14-2012, 07:22 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,858
I would say your method (main off, meter in) is perfectly acceptable and is the standard approach. The screws on the line side of the main breaker are hot, they are not isolated.
In a commercial setting, working in a panel with any accessible hot parts (no matter how small) is subject to NFPA 70E rules for hot work, resulting in extremely burdensome personal protective equipment requirements... which almost nobody actually complies with in circumstances like this.
mpoulton is offline   Reply With Quote
Old 01-14-2012, 11:50 PM   #11
Rewards Points: 506
Is this a safety statement or a legal/trespassing statement?
jlmran is offline   Reply With Quote
Old 01-15-2012, 02:14 AM   #12
Julius793's Avatar
Can be both, depending on your poco
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-15-2012, 03:11 AM   #13
" Euro " electrician
frenchelectrican's Avatar
Very simple .,, Both!!
I have allready survied couple meter blow up on me when when I did try to remove it ( I do used the specail tool for this ) and that why I do not want any homeowner to remove the meter at all for safety reason and many POCO will throw a fit when you remove it espcally with new smart meter they will send a signal when the meter is removed.
So for safety sake S.V.P Do not remove the meter yourself and everything from the main breaker to the POCO lines are unfused secondary and if something short out it will run like runaway welder until the cable burn out or transfomer give up smoke or cutout kicked out.
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
jbfan (01-15-2012), oh'mike (01-15-2012)
Old 01-15-2012, 12:44 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You as a homeowner never remove the meter. As an electrician on service call you don't remove the meter. You turn the main off whether it is remote or internal to the panel. You do have certain safety equipment/ clothing that is standard SOP.
What you did is perfectly acceptable, though possibly not advisable based on your knowledge. There are also guards that can be placed over the mains, it just depends.
There are many things that can be wrong in a panel that are life threatning, specifically current from an outside source on your grounding electrode system or a failed grounded (neutral conductor) of the utility and your grounding system making up for it. The later not so dangerous once the main is opened.
So there are several things to check before working, proper bonding for the situation and configuration of the service entrance and objectionable current for the most part.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 05:40 PM
Single breaker vs double pole breaker for MAIN tuckerz Electrical 11 11-16-2009 07:42 PM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 09:04 AM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 01:34 PM
