Main CH Series Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 02:23 PM   #1
Rewards Points: 164
Main CH series panel
I have a 100 amp CH series panel, and I just noticed the main breakers two switches aren't tied together any more, and the bottom ones broke. Can you purchase a main breaker replacement for the CH series? Menards and Home Depot don't carry them. Electrical supply place have them?
ryan50hrl is offline   Reply With Quote
Old 07-19-2012, 02:53 PM   #2
Rewards Points: 164
I'm assuming those should be tied together?
Old 07-19-2012, 03:13 PM   #3
Yes, the handle is broken and you should replace the breaker. They are still readily available. Here you go: http://www.amazon.com/gp/aw/d/B000BLFBKW
LooseSCruz is offline   Reply With Quote
Old 07-19-2012, 03:15 PM   #4
Your local supply house probably stocks them as well, just for the record. Not surprised that Big Orange doesn't, they're not quite common enough.
Old 07-19-2012, 03:24 PM   #5
Rewards Points: 164
That main breaker is not just a two pole.
Old 07-19-2012, 03:52 PM   #6
Ah, that makes things clearer. What you have is a CH2100L.
See: http://buys.relectric.com/2011/05/ci...ammer.html?m=1
Old 07-19-2012, 04:02 PM   #7
Rewards Points: 164
BAH****** 138 bucks for a refurbished breaker.........what the heck is that!!!
Old 07-19-2012, 04:13 PM   #8
That is the pain of having an out of date panel. Supply and demand is not working in your favor here.
Old 07-19-2012, 04:41 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I wouldn't call that panel out of date.
Old 07-19-2012, 04:47 PM   #10
Rewards Points: 164
I wouldn't have either.......but as eaton doesn't seem to make the breaker anymore......I guess thats where i'm stuck at...
Old 07-19-2012, 05:26 PM   #11
k_buz's Avatar
I don't think there is anything against using the other 100A main breaker...the one that is half the length as long as you have the hold down clip.
Old 07-19-2012, 05:28 PM   #12
Perhaps out of style would have been a better choice of words. I don't mean that there's anything wrong with it, just that replacement breakers are more expensive due to the fact that the panels aren't as commonplace as say a Murray/Siemens or a Sqaure D Homeline, at least in my area.
Old 07-19-2012, 08:54 PM   #13
Rewards Points: 164
Isn't there a difference between a main breaker and a feed breaker?
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
