Main Breaker Trips All The Time. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 04:13 PM   #1
hohadcr's Avatar
Rewards Points: 306
Question
Main breaker trips all the time.
Just rented a new office space. The electrical box has a main 100Amp breaker and 3 15amp breakers: one for lights two for plugs.
I am using some computers, air conditioners and fridge etc.
Today, I turned both air conditioners on, then when the fridge or both of the air conditioner turns on, I have no power at all in the room, including lighting.
I checked the status of the breakers, none is in a "tripped " position.
I turn the main breaker off and on again. After 1 to 2 mins, everything turns on. Then when fridge or air conditioners go on, everything is turned off in the room.
What could be wrong?
Thanks in advance
hohadcr is offline   Reply With Quote
Old 07-11-2011, 04:26 PM   #2
Electrical Contractor
kbsparky's Avatar
Loose or bad connection(s). Have your landlord call an electrician for repairs.
-KB
Old 07-11-2011, 05:11 PM   #3
hohadcr's Avatar
Rewards Points: 306
Our landlord is not doing anything. I am going to have to check the connections myself.
If it is just connections, I can make it right, correct?
Old 07-11-2011, 05:29 PM   #4
Rewards Points: 324
don't do it your self.you will held liable for any problems.send land lord a registered letter stating prob.give him three days to repair.if no respones send another and one to the building dept in your city.he will either fix it or loose a tennat.
oleguy74 is offline   Reply With Quote
Old 07-11-2011, 05:31 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
ABSOLUTELY NOT!
Call the landlord again. If he does not respond call an electrician and deduct it from your rent.
It may or may not be "just the connections". Regardless, the connections are UNFUSED terminations that cannot be turned off unless the power company does it. Even then, since this is a commercial space it is highly likely that it is illegal for you to do any electrical work there.
Old 07-11-2011, 06:31 PM   #6
I=E/R
a7ecorsair's Avatar
Are you sure it is a problem in your panel? If the main is tripped, turning the main off and on should restore power immediate not 1 to 2 minutes later.
a7ecorsair is offline   Reply With Quote
Old 07-11-2011, 06:38 PM   #7
hohadcr's Avatar
Rewards Points: 306
I will contact the landlord.
It is a good place for less rent compared to the rest of office buildings. All the renters here do all the fixing themselves... not wanting to create drama with the landlord and end up having to move out to a more expensive place...
Old 07-11-2011, 07:18 PM   #8
I do a LOT of clean up work in places like this.
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (07-12-2011)
Old 07-12-2011, 12:47 AM   #9
" Euro " electrician
frenchelectrican's Avatar
That one of few most common service call I get pretty often related to the office spaces when someone unqualfied try to fix it up and I have to clean up thier screw ups { due they do not follow the codés }
I just have one done not too long ago last nite. ( someone hook up wrong connection and end up 415 volts on the luminaires blew out 22 ballasts )
Merci,
Marc
Murray main lug center - what type of tandem breaker? cl or ncl? plove79 Electrical 4 09-01-2010 09:08 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Update: Power on several circuits comes and goes all at once, never trips breaker Michael H Electrical 9 07-03-2009 11:12 PM
Load Center Replacement - with or w/o main breaker? shepiii Electrical 3 01-30-2009 12:04 PM
Main Breaker won't stay on Please Help mikpowl Electrical 8 01-10-2008 10:22 AM
