Main Breaker Tripping - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 12:43 AM   #1
Question
Main breaker tripping
I have a 150 amp breaker box and for the the last 2 months the main trips if I have more than a couple things on at a time. Id be surprised if I was pulling more than 75 amps when it trips.
The house was built in the 50s but Im guessing the box was installed sometime in the 70s or 80s (couldnt find any dates on it). I noticed the grounding wire had come loose from the rod outside. I reconnected it but the main still trips.
Do I need to replace the breaker box or is something else causing this?
M. Ready is offline   Reply With Quote
Old 02-20-2009, 01:05 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
What electric appliances do you have? Electric heat? Anything new?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-20-2009, 01:30 AM   #3
Could be an old weak tired breaker.
Could be the bus connection behind the breaker.
220/221 is offline   Reply With Quote
Old 02-20-2009, 07:39 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
I have found this to the the problem with a main tripping, especially under a light load, 95% of the time.
Old 02-20-2009, 10:13 AM   #5
So does the breaker then feel abnormally warm?
Old 02-20-2009, 12:23 PM   #6
The breaker is never warm to the touch. Havent added anything new. The last time it tripped the only things on were 2 small (12.5amp) electric heaters, the TV, and one light. It can be any combination of things on that cause the breaker to trip. I have a propane furnace but use the electric heaters to cut down on the amount of propane I am using.
Old 02-20-2009, 12:30 PM   #7
Does that mean I need a new box or how do I fix this? Im on a tight budget and dont want to spend anymore than I have to.
Old 02-20-2009, 02:00 PM   #8
DIY'er
jamiedolan's Avatar
Replacing a main breaker is involved, it is not a DIY project for 98% of people. In most cases, the powerco needs to cut the power to the house before the breaker can be changed out.
A new box may very well be cheaper than a new breaker, depending on your panel, but there is a significant amount of work involved in installing a new panel.
Jamie
Old 02-20-2009, 02:20 PM   #9
Whats the make of your panel?
rgsgww is offline   Reply With Quote
Old 02-20-2009, 02:56 PM   #10
The current panel is a Square D. I dont plan to replace the panel myself. I just want to know what I need and will buy all the parts and have someone else come out to hook it up.
I had it trip a couple minutes ago and the only thing on was the TV, PC, 1 heater, and the washing machine. I know thats not anywhere near 150 amps.
Old 02-20-2009, 03:13 PM   #11
Homeline, qo?
Qo load center with breakers
http://www.flickr.com/photos/thebutners/366524475/
Homeline load center
http://www.flickr.com/photos/scottbb/202290783/
Old 02-20-2009, 03:34 PM   #12
DIY'er
jamiedolan's Avatar
I would allow the electrician that installs it use the equipment that they sell. It's likely going to be cheaper for them to use what they are familiar with than to buy something yourself.
Is the person your talking about having do this licensed?
Jamie
Old 02-20-2009, 03:43 PM   #13
This is a BAD idea. How do you know what to get? Just asking here online is not the right way to troubleshoot this problem.
Let an electrician come in and determine what it is he needs to get.
Old 02-20-2009, 04:17 PM   #14
Yeah, it's time to call someone.
Try and find an old guy
Old 02-20-2009, 04:29 PM   #15
If a usuable HD clamp-on ammeter is $50 and a service call is $500 you should buy the ammeter if it gives you better than a 10% chance of finding the problem.
And you can sell it again, afterwards.
Do some troubleshooting. If you end up calling a tech, he will be more likely to take you seriously.
Bad main breaker? jm8891 Electrical 13 11-09-2013 09:32 AM
Pool Main breaker keeps tripping beckyreyes Electrical 12 08-11-2013 04:06 PM
Main Breaker is tripping rdmccaw Electrical 18 02-05-2009 10:27 PM
Main house breaker keeps tripping cosmicmah Electrical 20 01-22-2008 12:36 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
