A Main Breaker Trip Nain 100 Amp Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2010, 12:57 PM   #1
Question
a main breaker trip nain 100 amp panel
hi.
i am a new member. i had a main breaker trip and had a hard time to reset it. so i went put in a new one. it seem to be holding. the house had a couple space heaters 110 volts that was on at the time.
i ask a elect. why it trip ,he couldn't tell with out seeing it. i could understand that.
so he gave me two things reasons that could cause it.
[a] the heaters could be all on same phase, causeing unblanced load.
i understand the unblanced load, but if you 100 amp panel with 3 heaters at only 110 volts and nothing eles on. ain't those heaters drawing well below the rating of the main breaker
[b] he check the ground to the water line.
stumps .02 is offline   Reply With Quote
Old 12-23-2010, 01:05 PM   #2
What is the rating of the heaters ?
What other electric load is there ?
Old 12-23-2010, 01:09 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Scuba,
This post is on the "Introductions Page".
Why wouldn't you (as a Moderator) move it to the "Electrical Page" where it would have proper exposure to those in the know?
Few will even notice it here.
XXX
Old 12-23-2010, 01:29 PM   #4
Ah...Thanks
I just answered it as a new post....did not realize where it was
Old 12-23-2010, 01:43 PM   #5
I=E/R
a7ecorsair's Avatar
Originally Posted by stumps .02 View Post
hi.
You replaced the Main Breaker? Did you pull the meter to remove power? I think we need a little more information to work with.
a7ecorsair is offline   Reply With Quote
Old 12-23-2010, 01:55 PM   #6
Electrical Supplier
Rewards Points: 150
It seems you might not know exactly what you are doing. Im guessing you dont know the danger you put yourself into or are a thrill seeker.
A "Main Breaker" Doesnt just "trip" arbitrarily unless it is defective. Generally space heaters use about 1500 watts each or 12.5 amps. This is about the 80% load rule on breakers.
What Im trying to understand is that if you replaced the 100 amp service disconnect or a branch breaker. If you have 3 heaters on one breaker it WILL trip it.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 12-23-2010, 02:21 PM   #7
Experienced
Jackofall1's Avatar
All I can say is YIKES!!!!!
Step away from the edge before you fall!!!
Proper grounding of meter main to breaker panel tns1 Electrical 3 09-08-2009 10:24 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 07:55 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Main breaker panel redline Electrical 1 03-19-2006 09:01 PM
