Main Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 07:10 PM   #1
I am struggling to get a grip around some amp questions.
On my main breakers it lists 150. So I would assume that my main breaker is rated for 150 amps. But when I add up all of the breakers I get 320.
What am I doing wrong??
Thanks.
skepace is offline   Reply With Quote
Old 11-28-2012, 07:21 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks.
Stop adding up all the breakers... And stop wondering about stuff, it works, leave it be.
Old 11-28-2012, 07:22 PM   #3
But I need to know if I have enough space to take out a 2 pole 30 amp for a 2 pole 60 amp.
How would I find this out?
Old 11-28-2012, 07:23 PM   #4
E2 Electrician
You could do a whole house load calculation... Whats the 2pole 60 for?
Old 11-28-2012, 07:24 PM   #5
Rewards Points: 324
you don't add up breaker size.you will never max load all ckts in your panel.
oleguy74 is offline   Reply With Quote
Old 11-28-2012, 07:27 PM   #6
Running a control panel that controls two 5500 watt elements plus 2 pumps. More than likely they won't be on at the same time but just in case.
Old 11-28-2012, 07:28 PM   #7
E2 Electrician
Who sized the 60 amp sub panel?
Old 11-28-2012, 07:32 PM   #8
From the main breaker the 60 amp 2 pole would go to a 60 amp 240v Spa Panel (GFCI) then to a control panel.
Old 11-28-2012, 07:33 PM   #9
E2 Electrician
So you're wiring a Spa? Im just curious on the back story, IMO, you are probably fine with the 150 AMP service.
Old 11-28-2012, 07:36 PM   #10
Sure. No worries. Using a Spa to get GFCI and I can take it with me when I probably sell my house in a couple of years.
Old 11-28-2012, 07:38 PM   #11
E2 Electrician
Not sure what you're doing but have fun and be safe....
Question about main panel grounding ACR_SCOUT Electrical 9 01-15-2012 11:24 PM
Fuse panel main breaker question cjm94 Electrical 5 11-16-2011 10:16 AM
Changing a breaker. Turn main power off first? noone Electrical 18 11-15-2011 08:08 PM
Basement improvement / AFCI Breaker Question BiOs2k Electrical 0 02-25-2011 11:32 AM
Main Breaker panel question stagger19 Electrical 5 08-15-2006 04:57 PM
