Main Breaker Getting HOT! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 10:39 PM   #1
Question
main breaker getting HOT!
hi all got a question for ya. my 200 amp breaker gets hot to touch when the dryer is running. only the dryer causes this. my question is how will I know if the breaker has just had it or the dryer has a problem ? help me out . thanks...........
enquiringminds is offline   Reply With Quote
Old 05-15-2013, 04:46 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,396
Does your dryer cord get warm?
Do you have a clamp meter and can you test the current draw at the panel.
How warm, and how did you notice a 200 main getting hot?
MTN REMODEL LLC is offline   Reply With Quote
Old 05-15-2013, 05:30 AM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
you must have this looked at from a professional ASAP .... that is a sign something is very wrong ..
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following 2 Users Say Thank You to Philly Master For This Useful Post:
Jim Port (05-15-2013), mm11 (05-15-2013)
Old 05-15-2013, 05:39 AM   #4
Rewards Points: 1,542
There is a loose connection in or under the breaker. If you let it continue the panel could be damaged beyond repair.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
oh'mike (05-15-2013)
main breaker tripping larsalan Electrical 12 07-17-2012 02:27 PM
running a subpanel from the main breaker on the pole. shocknawe Electrical 6 05-09-2011 09:51 AM
Main Breaker Melting rubberhead Off Topic 8 03-16-2011 07:50 PM
Remove Main Breaker from Subpanel fblankinship Electrical 5 10-28-2010 07:11 PM
Single breaker vs double pole breaker for MAIN tuckerz Electrical 11 11-16-2009 06:42 PM
