Main Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 08:46 PM   #1
Rewards Points: 12
Exclamation
Main Breaker Box
I am wanting to replace my 100 amp 20 breaker box with a 100 amp 30 breaker box. Would I need to call the electric company to turn the power off to the house to switch the box out or what is the best way to do this?
Brandon28 is offline   Reply With Quote
Old 11-12-2011, 08:52 PM   #2
Licensed electrician
Rewards Points: 1,010
A simpler and less labor intensive alternative option is to install a subpanel and leave the existing panel in place.
Old 11-12-2011, 09:26 PM   #3
Rewards Points: 12
Would I still have to call my power company to turn the power off to install a subpanel so i wont get shocked when i connect the subpanel to the main power
Old 11-12-2011, 09:41 PM   #4
The power company would not need to be called for the subpanel
Old 11-12-2011, 10:00 PM   #5
Rewards Points: 12
Exclamation
so how would i install the subpanel to the main panel without shocking my self
Old 11-12-2011, 10:01 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Not to be rude, but from this question, and the one for the oven, you really need to hire an electrician.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
Code05 (11-12-2011), frenchelectrican (11-12-2011)
Old 11-12-2011, 10:22 PM   #7
Rewards Points: 12
well thanks for your help....
Old 11-12-2011, 11:12 PM   #8
Code05's Avatar
Rewards Points: 1,104
Brandon, I know this is a DIY site, but your questions are even really basic for here. As electricians, your lack of familiarity with some pretty simple stuff is a warning sign to us to suggest you seek proper training or hire a pro.
We are not trying to be !@#$%&s, but we do not want to see you or someone else get harmed. Getting shocked hurts and electrocution is a nasty way way to go.
Code05 is offline   Reply With Quote
The Following 3 Users Say Thank You to Code05 For This Useful Post:
frenchelectrican (11-12-2011), Jim Port (11-12-2011), SD515 (11-13-2011)
Old 11-13-2011, 08:41 AM   #9
Rewards Points: 12
I know how to wire outlets, switchs, etc on the 110 side. Thats easy. But I am learning all of this new higher voltage side of things. So i would just have to be careful when i do it
running a subpanel from the main breaker on the pole. shocknawe Electrical 6 05-09-2011 10:51 AM
Main 100 amp breaker Tony vargas Electrical 1 04-26-2011 09:05 PM
Main Breaker Melting rubberhead Off Topic 8 03-16-2011 08:50 PM
Remove Main Breaker from Subpanel fblankinship Electrical 5 10-28-2010 08:11 PM
Single breaker vs double pole breaker for MAIN tuckerz Electrical 11 11-16-2009 07:42 PM
