Magnet Wire Ampacity - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 08:47 AM   #1
Question
magnet wire ampacity
I am confused about the current carrying capacity of copper magnet wire.
My alternator stator has 13 gauge wire that, according to my chart, has a rating or 10.357 max amps. My alternator is rated at 105 amps. What am I missing?
bizybily is offline   Reply With Quote
Old 11-04-2010, 08:59 AM   #2
Rewards Points: 1,536
In the alternator the magnet wire has a good enough insulation to not burn up and short circuit given the heat given off during the current generation process and heat fromt he nearby engine. The magnet wire is short enough in length that the volts dropped still leaves enough (12) to power the equipment in the car.
Magnet wire insulation (enamel) is not meet code to allow magnet wire to be strung through walls or conduits in a building in place of THHN or whatever.
Old 11-04-2010, 09:54 PM   #3
I=E/R
a7ecorsair's Avatar
There are also multiple strands of wire carrying the current.
a7ecorsair is offline   Reply With Quote
Wire Nuts Cutting Wire dw1256 Electrical 2 04-15-2010 01:12 PM
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
