Magnet Pull Force Question Here - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 12:36 PM   #1
Magnet pull force question here
if a magnet is rated for say 50 lbs, is that an accumulative number meaning;
say its latched onto something on the north side, does that mean south side strength would diminsh,
or
does that rating signify on north side it has 50 lbs and on its south side it will also have 50 lbs of force?
Anyone!
jratftcc is offline   Reply With Quote
Old 05-16-2013, 12:44 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
Having something attached to one end of a magnet does not significantly change the amount of magnetic flux going through the other end of the magnet. If something is attached to one end, you should be able to attach something to the other end and it should hold with about the same force. The rated pull of the magnet is probably overly optimistic. It will only pull that hard when attached to flat, thick, pure, clean iron. The actual usable holding force in reality will be much less than the ideal maximum.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
MTN REMODEL LLC (05-16-2013)
Old 05-16-2013, 12:46 PM   #3
It means it can hold 50lbs of force total. if you attached the magnet to a fixed surface, and then hung something to the bottom, the most you could hang from it would be 50lb. Keeping in mind this is strictly talking about a vertical hanging load.
OCPik4chu is offline   Reply With Quote
Old 05-16-2013, 12:50 PM   #4
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
or
Anyone!
I'm no physicist but my knowledge of pull force and testing of items by pull or torque is the gravitational force of the mass (item). So... if you have a magnet rated for 50lbs and you latch it to the north, you would need a gravitational pull strength of more than 50lbs in a south direction to unlatch it.
I hope this was helpful or at least amusing...
InspectorZo
Nailing problems and building solutions.
Facebook | Twitter
InspectorZo is offline   Reply With Quote
Old 05-16-2013, 01:23 PM   #5
Thanks everyone...kinda makes sense
Ill buy a a few small magnets and test them out first, before buying the true sizes. Im not made of money which is why I ask questions....so I dont have to spend money testing myself things that are already mathematic.
Appreciate all the input.
The Following User Says Thank You to jratftcc For This Useful Post:
InspectorZo (05-16-2013)
Old 05-16-2013, 03:30 PM   #6
Uncoated flat magnets on very flat surfaces hold best. The perfect flatness of the surfaces is the most important thing. The closer the contact between the magnet and the metal surface, the larger the force. 0.005" separation may be good and look flat, but 0.001" separation will provide much more holding force. Paint on either surface will reduce the holding power greatly. You also want the metal surfaces to be thick, wide, and pure iron or steel.
Old 05-17-2013, 08:57 AM   #7
thanks poutlon for that...I will defintely keep all that in mind.
smooth surfaces and no paint
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
Recapturing Refridgerant Question mtnlovrs HVAC 10 09-04-2011 10:33 PM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
