Machine Install 480v #8 Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 12:36 AM   #16
Originally Posted by mpoulton View Post
That's not a reset button, it's a test button. That's why it doesn't say "reset", it says "push to trip". Frankly, you have no business working in the panel and it's scary that you're attempting any troubleshooting on it at all - especially doing voltage measurements with a meter with the panel cover off. You are not qualified to do this work safely. I think you have no idea what a 480V arc flash accident looks like. One slip with a screwdriver or multimeter probe, or a minor failure inside the meter (is it a CAT III rated meter???) will blind you and burn you, or worse.
Poulton,
I tested the power at the outlet, not at the source sir. I have not touched anything on the panel, other than to flip the switch and press the test button on the circuit breaker.
jamesthames is offline   Reply With Quote
The Following User Says Thank You to jamesthames For This Useful Post:
mpoulton (10-10-2012)
Old 10-10-2012, 12:38 AM   #17
Electrical Contractor
kbsparky's Avatar
Where does the breaker get its power from?
Is it mounted in a panel, or in a separate enclosure?
-KB
Old 10-10-2012, 12:44 AM   #18
The picture showed a stand-alone breaker, with line and load lugs ....
The photo was just to identify the breaker boss. the breaker is hooked up to a triphase panel that can run up to 499 V as per the electrician. There's three huge copper bars behind the panel. The breaker is one of 3 on the panel right now. the wire feeds into the circuit breaker, which then feeds a primary disconnect. So the circuit breaker gets its power from the panel.
Old 10-10-2012, 12:47 AM   #19
kbsparky's Avatar
You got juice at the primary disconnect?
-KB
Old 10-10-2012, 12:53 AM   #20
the honest answer is I don't know, because I am afraid to run the voltmeter off the panel. But at the outlet there is no power, so I assume the problem comes from the origin, not at any point in between. And just to be sure, i turned all the disconnects off and on, there are no problems with the disconnects. so I have assumed that there is no power running from the panel, which means either it's the circuit breaker, or the panel. What I hope is that it's just a simple reset issue for the circuit breaker. But my fear is that the circuit breaker is burnt or something, and needs to be replaced.
Old 10-10-2012, 01:52 AM   #21
It's mounted in a panel, it gets its power from the panel
Old 10-10-2012, 07:43 AM   #22
kbsparky's Avatar
Too many assumptions and hopes here..
Working on 480 Volt systems is not a DIY project, with serious injury and/or death being possible. Much more possible than working with something like 120 Volts, as would be commonly found in a dwelling.
Best thing at this point is to call a qualified electrician who has the proper personal protection and testing equipment.
Those 480 Volt breakers are not cheap, and playing assumption and hit-or-miss can quickly add up to greater costs that one realizes ...
-KB
The Following 4 Users Say Thank You to kbsparky For This Useful Post:
jamesthames (10-10-2012), jbfan (10-10-2012), Kapriel (10-10-2012), Oso954 (10-10-2012)
Old 10-10-2012, 08:06 PM   #23
KB, thanks for the good advice. I did have a certified electrician come check it, it simply wasn't reset properly. Now it's all ok. Thanks to everyone who replied to this thread, you guys are the best
Old 10-10-2012, 08:17 PM   #24
Missouri Bound's Avatar
Thanks for getting back to us with the results.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 10-10-2012, 08:23 PM   #25
Missouri Bound I believe called this many posts back.
Very simple.
Congratulations MB !
Kapriel is offline   Reply With Quote
The Following User Says Thank You to Kapriel For This Useful Post:
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 04:15 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 08:23 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Wiring help three wire to two wire install israelsoto99 Electrical 1 06-28-2009 11:24 AM
