Lutron Dimmers And MR16s - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 12:09 PM   #1
Lutron Dimmers and MR16s
I have MR16 light bulbs around most of my house. Otherwise I have the standard light bulbs (not sure what they are called, it's your typical screw in bulb).
I am installing lutron dimmers, and specifically purchased the one for incandescent halogen bulbs (600w). Would these work for the MR16s? Or do I need to get the (much more expensive) dimmers for low voltage or magnetic voltage (not even exactly sure what they are called).
SO basically, are MR16 bulbs (with the two pin connectors) deemed an incandescent halogen?
Raym50 is offline   Reply With Quote
Old 07-28-2012, 12:47 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Dimmers are based on what they are controlling, so you need to find out what type of transformer is powering your MR-16 lamps, magnetic or electronic transformers.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Raym50 (07-28-2012)
Old 07-28-2012, 01:37 PM   #3
Thanks. How do I find out? Would it say so on the inside of the bulb housing? I'll send pics soon.
Old 07-28-2012, 04:24 PM   #4
Master Electrician
If you pull the bulb out and detach the can from the fixture you should get a good view of the ballast from there. All info will be on the ballast.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-28-2012, 05:56 PM   #5
For what it's worth attached are pictures of the inside of the can. Do I need to pull out the can entirely to find out this info? The sticket on the inside reads: input "120vt 60hz ac" It also is labeled LV 4000b. THe outron switch I bought reads 120v~ 60hz (incandescent/halogen). Seems like I should be good, but I don't want to burn the house down!
Old 07-28-2012, 09:29 PM   #6
Master Electrician
If you detach the can then you'll see the ballast type. If you hook the dimmer worst thing that will happen is the bulbs won't dim right.
