Lutron Dimmer Light Switch W Low Voltage Halogens - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 02:25 PM   #1
lutron dimmer light switch w low voltage halogens
Hi, all, and Happy New Year to the best advice-givers in cyberspace!
We have two sets of low-voltage under-cab halogen lights in our kitchen; we RARELY use them. Suddenly one set did not work, and it turns out the Lutron dimming switch is not functioning. I swapped it for a new one, and all is well.
My question: What on earth would make such a switch quit after 8 years of very infrequent use. We have dimmer switches all over the house, all the others receiving much more use... I'm wondering if I should be concerned about something else up the line.
Thanks, and enjoy your holiday.
Vince
pdxrain is offline   Reply With Quote
Old 12-30-2011, 02:30 PM   #2
Master Electrician
Rewards Points: 3,828
Vince
Low voltage lighting usually requires low voltage dimmers. Either a magnetic dimmer or an electronic dimmer depending upon the type of transformer.
brric is online now   Reply With Quote
Old 12-30-2011, 02:55 PM   #3
brric: Thanks for the reply. That's very interesting, indeed. The two dimmers installed by the electrician 8 yrs ago are both the Lutron AY-600P (not the AYLV-600P). The transformers he installed have the following label:
Sea Gull Lighting Products
Model 9454-12
Input Black 120V
Output Red 12VAC, 60W Max
Class II
The bulbs are B16120X, which a search online suggest are Xenon 12V 13W bulbs.
The dimmer I just put in is also the AY-600P, like the original. Should I pull it out and replace it? Is it dangerous and should I replace the one still working on the other set of lights? Thanks for your help.
Vince
Old 12-30-2011, 03:47 PM   #4
Master Electrician
It is not dangerous. You might fry a dimmer or an XFMR at worst.
Old 12-30-2011, 05:00 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,202
If the low voltage lights use an electronic type tranny
Then you need the correct type of dimmer,
The power supply needs to be dimmer compatible,
And the dimmer needs to be special type !
look for words like "leading edge" or "trailing edge"
these are the type of dimmers for electronic type trannys.
Normal ones sometimes work, but usually dont last too long.
Sometimes dimmers can fail for no obvious reason,
theres a lot of crap on the lines that they must contend with
and some cheap dimmers are not able to cope.
A proper spike filter might help here!
dmxtothemax is offline   Reply With Quote
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 03:00 PM
Wireless light switch with dimmer? joeg679 Electrical 3 03-24-2011 12:51 PM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
Dual light switch dimmer? techprincesse Electrical 9 07-02-2010 11:40 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 02:39 PM
