Lubricant In Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2008, 01:33 PM   #1
Lubricant in Panels
What is the lubricant that is used on the main lugs of a service panel?
The reason I ask is a need to replace a MAIN panel on a remote barn on my property. I have access to a used, but in good condition panel that lacks the lube found in new panels.
Randell Tarin is offline   Reply With Quote
Old 02-11-2008, 02:01 PM   #2
Rewards Points: 2,350
That is an antioxidant used for aluminum conductors. Ideal sells it under the brand name Noalox, you can get it at any hardware store in the electrical section. It isn't so important with copper wire, but it is absolutely necessary for aluminum.
InPhase277
Old 02-11-2008, 04:08 PM   #3
Electrician
InPhase277
Actually its not ever required for aluminum, but knock your socks off...
chris75 is offline   Reply With Quote
Old 02-11-2008, 04:19 PM   #4
Have you ever seen aluminum conductors that haven't been greased? My God, man! I have. It may not be required, but it is necessary. I even put it on large copper conductors.
InPhase277
Old 02-11-2008, 04:25 PM   #5
Electrician
InPhase277
If it was so important dont you think it would be in the NEC? or required by a manufacture? and how do you know the damage was not caused from a loose connection, I have never seen any proof or research that Noalox does anything... I would spend my money on a torque wrench before I wasted it on Noalox...
Old 02-11-2008, 04:46 PM   #6
If, as was stated, the lubricant is used to prevent oxidation how can you make the statement: "how do you know the damage was not caused from a loose connection?"
IMHO, I would think that damage from oxidation and damage caused by arcing are quite different from one another and easily distinguishable.
Old 02-11-2008, 04:51 PM   #7
I just know that every time I've ever seen a connection without it, it always had signs of corrosion at the interface of the two metals. I've also spent alot of time rewiring homes with aluminum branch circuit wiring, not the same thing I know, but oxidized aluminum connections are most certainly a problem.
I've even used noalox on outside connections in flood lights and on the threads of buried rigid and IMC. Better safe than on fire!
How many other things does the code not require that you think should be in there? Anyhow, try passing an inspection in my area without it...
InPhase277
Old 02-11-2008, 04:52 PM   #8
Electrician
Would you like to show me a picture of a damaged wire from oxidation?
Old 02-11-2008, 04:56 PM   #9
Electrician
InPhase277
Just so you dont hate me I do use Noalox on my AL. services... But its just a bad habit...., The stuff is just snake oil...
Old 02-11-2008, 05:15 PM   #10
I will if you'll show me a picture of how the damage is similar. Aren't we talking apples and oranges?
Besides, I can't show you a picture of any oxidized wire because all mine are lubricated.
Old 02-11-2008, 05:20 PM   #11
Electrician
Yes, the thing is, I have never seen a bad wire from oxidation, just loose connections... so if you think it will make the installation more safe then use the stuff...
Old 02-11-2008, 07:33 PM   #12
Here are some service conductors that had been "temp spliced" for about 20 years. All things considered, I was amazed at their good condition.
220/221 is offline   Reply With Quote
Old 02-11-2008, 07:47 PM   #13
Electrician
Thanks buddie...
Old 02-11-2008, 08:06 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I don't believe antioxidant compound was ever required for the aluminum wire but for the termination lug and only if the manufactuer required it. Seems to me it was always stated that it was recommended. Also with the 'new' al alloys we use today it really isn't necessary... but to add noalox was the least liked by me whenever I used it... penetrox is a much better product IMO.
UL 486B (par. 7.5, p.12) "If specific instructions for assembling the connector to the conductor are furnished with the connector by manufacturer such instructions are to be followed in the preparation of the terimation except the conductor is not to be brushed or abraded and antioxidant is used only if the connector is pre-filled with the antioxidant.
"From the white book"
Old 02-11-2008, 08:14 PM   #15
I HAVE however seen MANY oxidized aluminum wires.
The last couple were feeders...... underground PVC to a 100 amp apartment panel....maybe 4 years old. A slight nick in the insulation on installation combined with sitting in a water filled portion of the conduit turns the Al wire to white powder.
I have not seen oxidized conductors in a dry location.
Raised Panels? JFD140 Carpentry 9 09-19-2007 07:43 AM
Pillar fence post with recessed panels on two sides derby2* Carpentry 1 05-18-2007 11:52 AM
