LP Gas Line Bonding - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 10:08 PM   #1
I=E/R
a7ecorsair's Avatar
LP Gas line bonding
Finishing up my electrical on new house. Do I have to bond the gas pipe for the LP furnace to the concrete encased electrode (Ufer)? The furnace and Ufer stub are in the crawl space. The reference I have says the bonding wire size is based on the electrical feed to the furnace which is a 15 amp circuit. My LP supply is fed to the house underground by copper line. From the second regulator (the one on the house) gas is fed into the crawl space with yellow plastic covered flexible pipe. There is an iron tee for a take off to the tankless water heater and another tee for the kitchen stove. The line ends at the furnace where it connects to 1/2 black iron pipe. What needs bonding?
a7ecorsair is offline   Reply With Quote
Old 01-18-2011, 10:12 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
ask your inspector.
The gas line is supposed to be considered to be bonded through the egc of the circuit that serves the appliance BUT I have had more than one inspector require me to bond the grounding electrode system to the piping including one that required a bonding jumper around any meter or pressure regulator.
Old 01-18-2011, 11:23 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your yellow flexible piping is called CSST and is required to be bonded by the manufacturer due to its tendency to have small holes blown out of the thin side wall from indirect lightning strikes. This article should sum it up for you.
http://www.toolbase.org/pdf/techinv/...ngconcerns.pdf
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-19-2011, 08:21 AM   #4
I=E/R
a7ecorsair's Avatar
Stubbie, very interesting reading. Thanks for the link.
NFGC and the NEC have separate interests in this area so I guess the best thing is to talk to my electrical inspector and find out what he expects.
Old 01-19-2011, 08:41 AM   #5
nap
You talking to me?
nap's Avatar
HHmm, not sure where but I think I heard that somewhere.
Gas lines are one area the inspectors around my area seem to not be able to come to a consensus about. I have had totally opposite directives given me in nearly identical situations. I have kind of given up trying to keep ahead of who is going to order what this week so I simple ask the inspector what he is going to require.
I do what I know, or believe to be correct and then add whatever they want. It's easier than arguing about it. The cost to implement whatever they require is generally a minimal cost, relatively speaking, so it isn't that big of a deal.
Old 01-19-2011, 09:21 AM   #6
I=E/R
a7ecorsair's Avatar
It almost looks to me like the person who installs the CSST should do the bonding....
Old 01-19-2011, 09:36 AM   #7
I=E/R
a7ecorsair's Avatar
I found the answer in MN builing codes not the electrical codes
Old 01-19-2011, 10:21 AM   #8
UAW SKILLED TRADES
Stubbie's Avatar
I'm not sure I want the plumber trying to figure out bonding but I understand where your coming from. Personally I just would not use the stuff, ease of installation is one thing but I don't like the idea of pin holes in my gas piping and then trust bonding to prevent that from happening with lightning strikes. My experience with lightning is it seems to have a mind of its own regardless of what us mortal humans seem to think.
Stubbie
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 06:31 PM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 09:30 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
