Lowering Verizon's Phone Line - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 09:40 AM   #1
lowering verizon's phone line
I am putting in a new drive way and will need to cut a bank down approx 5 feet and there is a Verizon telephone line running through where i need to excavate. Verizon is wanting $5995 to lower the line! We all KNOW it dose not take $5995 to lower a line for a home drive!! Dose anyone know if I can hire a private contractor to do the job? -Or am I just stuck with Verizon? PS I live in Central VA
romeo4601 is offline   Reply With Quote
Old 03-14-2011, 10:26 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
is it just your line or a whole bunch? the latter i can see the price. yours u might be able to dIY
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-14-2011, 10:33 AM   #3
a 5' drop is a new line not just slack being taken up. probably not splicing
The older I get the better I was
Old 03-14-2011, 10:54 AM   #4
Rewards Points: 126
I would do it myself. But I cannot tell you to do it yourself. Better be sure its just phone and not the service drop.
Old 03-14-2011, 10:55 AM   #5
he doesnt say what size line
Old 03-14-2011, 11:00 AM   #6
Rewards Points: 1,492
Probably better not to do it yourself because if you cut the line with a backhoe then all holy hell will break loose.
If you have a utility easement over your property, any use of that strip of land has to be compatible with the utility company usage.
Do you really need to do your driveway project?
The Following User Says Thank You to AllanJ For This Useful Post:
tpolk (03-14-2011)
Old 03-14-2011, 11:09 AM   #7
Well no it would not be just my line because it runs on an a utility easement along the county maintained highway!
Old 03-14-2011, 11:11 AM   #8
thats no diy
Old 03-14-2011, 11:13 AM   #9
I am building a house and that would be the only way to access the new home! but yeah from what i here if you cut the phone companies lines its not pretty! I think there would be an utility easement through there..
Old 03-14-2011, 02:53 PM   #10
joed's Avatar
Rewards Points: 12,328
If it's a main trunk line like I think you are saying then you don't have much choice.
If was just the drop to your house I would DIY.
Old 03-14-2011, 07:15 PM   #11
I'm a retired telco repairman.
Once I had a call to check out a cable trouble and found a fellow and his machine digging holes.
I asked him if he realized that he had cut a cable. He said that he did, but only cut a little cable and missed the big one.
Turned out the little cable was a fibre optic cable that carried 500 long distance lines. The big one that he missed was an older, copper cable, with 50 local phone lines.
Its really difficult to judge what is being carried on a cable by its appearence, so its best to be cautious.
Perhaps a smaller machine would be able to work under the Verizon line.
Old 03-14-2011, 07:15 PM   #12
Does the line run across the entire frontage of your property? Although I am not sure, there may be some provision for giving you some access to the property. For example the telephone company gets to choose where the driveway goes and then has to modify the line at their expense.
Old 03-14-2011, 09:08 PM   #13
I=E/R
a7ecorsair's Avatar
This is a buried line, yes? Next, is the line crossing your property or is it in a road right of way that is owned by the county?
a7ecorsair is offline   Reply With Quote
Electrical outlet phone jack extension? mikehende Electrical 3 11-28-2007 08:05 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-17-2007 11:46 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 11:35 AM
