Low Voltage Wiring For LED Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 02:11 PM   #1
low voltage wiring for LED lights
how deep should this be underground, and does it need to be in conduit or any other kind of pipe?
jimnj is offline   Reply With Quote
Old 06-08-2012, 02:28 PM   #2
joed's Avatar
Rewards Points: 13,718
WE need more details of what you are attempting to do.
Old 06-11-2012, 06:29 AM   #3
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
If you're talking about LV landscape lighting, the only issue is how deep will the shovel, hoe, tiller you use go? There is no danger in cutting a LV wire, you'll just lose your lights and, if the power is on, maybe your transformer.
JulieMor is offline   Reply With Quote
Old 06-11-2012, 06:34 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
6" minimum.
voltage detected -no lights eatonjr907 Electrical 6 04-26-2012 09:17 PM
Wiring 6 Recessed Lights in Kitchen shawjd1 Electrical 3 01-27-2011 07:53 PM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 05:40 PM
Low Voltage Wiring Malibujim Electrical 2 05-07-2009 07:52 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
