Low Voltage Wiring For Ele. Inline Duct Damper - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 04:26 PM   #1
Low Voltage Wiring for Ele. Inline Duct Damper
I am installing a generic air flow duct to allow some outside air into my workshop during the warmer months. The duct is in a really high spot and I didnt want to use a manual damper so I purchased an electric inline damper to allow me to close it from a switch in the winter months.
Now I am trying to wire it to a switch instead of a thermostat (the directions say a Low Voltage thermostat is required). The instructions can be seen here:
http://suncourt.com/ZoneMaster_Instructions.html
Basically I want to know if I can use a standard single pole switch in place of the low voltage thermostat mentioned in the installation instructions.
And if NOT, what other options do I have to switch this instead of using a thermostat?
Any thoughts are appreciated!!!
mntnvew is offline   Reply With Quote
Old 06-07-2009, 04:59 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
yes you can but why not use a t-stat?
Old 06-07-2009, 05:26 PM   #3
Exterior thermostat?
Any notion on how to wire the switch, is it the same just disregard the thermostat graphic in instructions and use the two wires for the single pole switch per usual?
Thanks!
Old 06-07-2009, 05:55 PM   #4
nap
You talking to me?
nap's Avatar
the switch; yes, just put it inline of the low voltage line just like the t-stat is.
exterior t-stat? I thought you said this was in a workshop.
Old 06-07-2009, 07:25 PM   #5
You can connect the transformer to 120 VAC and install the switch in the low voltage line in place of the thermostat connection or wire the transformer direct the the dampener and use the switch to turn the 120 VAC on and off the the transformer.
hayewe farm is offline   Reply With Quote
Old 06-07-2009, 07:36 PM   #6
I like your idea of switching the transformer. Then when its turned off, absolutely no power will be used.
Old 06-07-2009, 08:06 PM   #7
nap
You talking to me?
nap's Avatar
the power used by a small transformer is minimal and switching the 120 voltage means he will have to install cabling and or conduit and boxes etc as required per code.
the low voltage wiring can be a phone line run across the floor if he wants.
Old 06-07-2009, 08:26 PM   #8
What you say is true, unless he uses a lamp cord switch and plugs it into a receptacle.
I wonder what the current rating for this damper would be.
As the damper will only be operated for awhile in the summer, why not have all shut off for the rest of the year!
Old 06-07-2009, 11:45 PM   #9
Yeah but I dont want it to open when I have my heat on in the shop in the winter, so an interior t-stat is really useless. If it was outside then it would work, but I am not keen on putting t-stat outside
I will just switch it. i purchased a N/C (Normally Closed) damper so I will actually only have to give it juice to open it during the summer and here in Montana that is only 4-5 months if we are lucky
Thanks, I can always count on this forum for solid advice (8 out of 10 times anyways
L8R
Old 06-08-2009, 12:06 AM   #10
... or wire the transformer direct the the dampener and use the switch to turn the 120 VAC on and off the the transformer.
I like this idea the best. Can anyone confirm my diagram assumptions below, better safe then sorry
Old 06-08-2009, 02:14 PM   #11
Your drawing is correct for using a switch in the low voltage circuit. Or you can add apower cord to the transformer and wire direct to the dampener. No switch required. Plug it in dampner open, unplug it dampner closed.
Old 06-08-2009, 02:18 PM   #12
Excellent, thank you!
Old 06-08-2009, 02:19 PM   #13
Rewards Points: 2,350
To be compliant, the transformer needs to be mounted to a junction box, and the splices made appropriately.
Old 06-08-2009, 02:22 PM   #14
Right, I guess that means I "cant just wire a cord". I have junction boxes with knockouts and will attach the transformer accordingly, thanks for the reminder though
Old 06-08-2009, 03:15 PM   #15
zpm
yeah, right
Most damper actuators don't use much power, typically a couple of watts at 24vac. An old sprinker timer transformer plugged into a switched receptacle would be another option.
zpm is offline   Reply With Quote
NM Wiring Located Near Heat Duct Pineapple Electrical 14 11-05-2008 12:05 PM
Connecting inline duct fan to furnace dlem HVAC 1 02-11-2008 06:50 PM
Old Low Voltage Wiring srwjr Electrical 14 01-24-2007 08:29 PM
Wiring inline duct fan to blower motor cleininger HVAC 3 12-12-2006 08:55 PM
