Low Voltage Wiring For Central Vac - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2008, 07:35 AM   #16
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,880
Low voltage wiring for central vac
In that case, there would be 14/2 ran to an outlet nearby, or at the face.
gregzoll is online now   Reply With Quote
Old 12-21-2008, 06:10 PM   #17
If you still have this problem, determine if the system is using 2 pair low voltage phone wire, figure out if there are any joints or any wires eliminated. Because 2 pair is brittle and breaks easily I like two use two strands for each contact, ie black and green vs yellow and red. If doing this be sure to follow the same pattern through out the house. Be sure this pattern is replicated where any pipes branch out to another section of the house. A good installer will have followed the pipe path with the wire and strapped it to the pipe. When you terminate at the machine pair the wires in the same pattern.
Chemist1961 is offline   Reply With Quote
Old 12-21-2008, 06:18 PM   #18
Phone wire insulation can stand at least 56vdc, which works out to 40v rms.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 02:50 PM
Old Low Voltage Wiring srwjr Electrical 14 01-24-2007 08:29 PM
