Low Voltage Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 01:58 PM   #1
South Jersey
Low voltage wiring
I have to get an electrical inspection and have en electrical permit for low voltage wiring for my 7 zone sprinkler system install.
Has anyone else done this and can offer some words of advice? What exactly ARE the codes for installing LVW? Do I need to run it through metal conduit? Are there certain restrictions I have to meet? Is there a site I can download a copy of the electrical codes for NJ? I am using 18ga 5 conductor direct burial cable if it makes a difference. I am most concerned about what is required inside the house to be code compliant.
I was kind of surprised when the township code official told me I needed an electrical permit.
Reddhead is offline   Reply With Quote
Old 09-12-2010, 09:37 AM   #2
Rewards Points: 1,548
Inside the house, all wires fished through or buried in walls must have certain non-flammability characteristics, I don't remember what the code letters are. CL3? CL2?
Generally (not sure for NJ) low voltage wiring splices don't need to be enclosed in junction boxes when the low voltage wires did not run through the same conduit as house current wires. But any joints and splices have to be accessible (reachable through a removable cover plate).
Outside you would not want to direct-bury joints and splices even in direct burial cable. Boxes with caulked openings where the wires come in are desirable and may be the same boxes where the water valves are located.
Old 09-12-2010, 10:23 AM   #3
South Jersey
Thanks Allen
The wiring will all be in my unfinished basement. One day the basement will be finished so I need to keep in mind what is required for the future.
I'll have to check the jacket on the cable too.
low voltage wiring for niche lighting 8roty Electrical 4 01-16-2010 07:17 AM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 06:48 PM
wiring Dual voltage motors tiquilagold Electrical 12 07-13-2009 10:24 PM
Low Voltage Wiring Malibujim Electrical 2 05-07-2009 07:52 PM
Old Low Voltage Wiring srwjr Electrical 14 01-24-2007 07:29 PM
