Old 05-05-2009, 06:28 PM   #1
Low Voltage Wiring
I have previously installed low voltage lights outside, but this time there's a new twist. I know the wiring is designed to be buried, normally without being in conduit. Now I want to run the wiring on top of a pergola, I finished last year, to some down lights hidden in the beams. Am wondering if the wire will hold up to the sun, if it is exposed instead of being buried. Should it be in conduit?
Malibujim is offline   Reply With Quote
Old 05-05-2009, 08:03 PM   #2
DIYer
Low Voltage Wiring
What are the markings on the insulation?
Gigs is offline   Reply With Quote
Old 05-07-2009, 08:52 PM   #3
Low Voltage Wiring
OK, it looks like the wire is OK ( I hadn't bought it yet ). "UL 2/C 12 AW 60 C VW-1 150V UNDERGROUND Low Energy Circuit Cable Sunlight Resistant." I hadn't noticed the "Sunlight Resistant" marking. I also had some older cable that says sunlight resistant. Since the wire will be run between 2x10's on top of the pergola, ai should be partially protected from the sun.
Low voltage thermostat wiring dirtpig538 General Discussion 2 02-14-2009 01:48 PM
Low voltage wiring for central vac leafyme Electrical 17 12-21-2008 06:18 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
Old Low Voltage Wiring srwjr Electrical 14 01-24-2007 08:29 PM
