Low Voltage Wire Repair On Lights Outside - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 06:18 AM   #1
low voltage wire repair on lights outside
If I move a light will black tape be enough to cover and seal the old hole made in the wire? Do I need to double wrap it or what? Thanks
kirkaldy is offline   Reply With Quote
Old 06-04-2012, 06:28 AM   #2
Rewards Points: 14,010
Delete
Old 06-04-2012, 06:40 AM   #3
bbo
Originally Posted by joecaption View Post
Hole in the wire
Is this old knob and tube wiring?
Your post makes little sence to me.
Any juntions, splices, or live dead ended wires need to be in an approved electrcal box with a cover and be accessible.
its outdoor low voltage from the looks of his title.
I believe the OP needs to look for direct burial splice connectors.
big box or local hardware should have them.
bbo is offline   Reply With Quote
Voltage drop? Lights dim with load on different circuit. nezwick Electrical 28 08-14-2012 10:18 AM
landscape lighting wire ? voltage drop daddyt Electrical 11 06-26-2011 11:51 AM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
2 lights from 1 switch, w/ no wire directly from light1 to light2 conradA Electrical 4 03-31-2010 10:25 AM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 08:46 AM
