Which Low Voltage Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2007, 10:18 AM   #1
Question
Which low voltage wire
Recently I had new garage doors installed professionally.
They did not hide the low voltage wiring. After spending all day fishing new 20 gauge low voltage wire behind the drywall I find it is multistrand wire whereas the original is solid. Is it OK to use multistrand low voltage wire (as I do on my boat ) or is there some reason I must use single strand (solid) wire ?
Scozz
scozzer is offline   Reply With Quote
Old 02-18-2007, 10:27 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
You will be fine using the wire you ran.
Old 02-18-2007, 11:56 PM   #3
Thank you. I didn't want to cover up the holes in the drywall only to find I should have used a solid wire.
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 10:58 AM
