-   -   Which low voltage wire (http://www.diychatroom.com/f18/low-voltage-wire-6564/)
scozzer 02-18-2007 09:18 AM
Recently I had new garage doors installed professionally.
They did not hide the low voltage wiring. After spending all day fishing new 20 gauge low voltage wire behind the drywall I find it is multistrand wire whereas the original is solid. Is it OK to use multistrand low voltage wire (as I do on my boat ) or is there some reason I must use single strand (solid) wire ?
Scozz
jbfan 02-18-2007 09:27 PM
You will be fine using the wire you ran.
scozzer 02-18-2007 10:56 PM
Thank you. I didn't want to cover up the holes in the drywall only to find I should have used a solid wire.
