Low Voltage Undercab Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 11:06 PM   #1
Low voltage undercab lighting
Hi all,
I want to install two low voltage undercabinet lights in two zones in my kitchen (with two transformers). In one zone, I have a spare receptacle available (my over the range microwave plugs into the other).
Q1: Can I plug the transformer for my undercabinet light into this spare socket?
Q2: Since I got a hard wire transformer (american lighting), can I just put a plug on the the HV side of the transformer in series with a feedthrough rocker-switch and plug it into the spare socket?
Q3: In the second zone, I do not have a spare receptacle to plug in. I was hoping to tap off the small appliance ckt into a separate socket located *inside the cabinet* and do the same that I did in the first zone. Is this OK?
Thanks in advance for any suggestions...
wariarr is offline   Reply With Quote
Old 03-26-2011, 11:09 PM   #2
Licensed electrician
Rewards Points: 1,478
The small appliance branch circuit cannot be used.
Your microwave instructions most likely call for a dedicated circuit just for the unit.
Low Voltage LED Lighting Cultcab Electrical 19 07-13-2012 03:37 PM
Low voltage landscape lighting rjniles Landscaping & Lawn Care 2 09-24-2010 09:55 AM
low voltage wiring for niche lighting 8roty Electrical 4 01-16-2010 07:17 AM
How to get low voltage through a corner pantry for cabinet lighting? ClemsonJeeper Electrical 7 11-11-2009 09:44 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
