Low Voltage Transformers In A Metal Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 01:43 PM   #1
Rewards Points: 95
Low voltage transformers in a metal box?
I need to mount a 110V-24V transformer for the ventilation equipment in my garage. I also have a doorbell transformer on the wall in my garage that I'd like to enclose. The doorbell transformer is mounted on the plate covering a 1-gang metal box in the wall. So, I thought I'd accomplish both of these by removing the doorbell transformer from the existing box, mounting a Wiegmann 8x8x4 box over the 1-gang box, and mounting both transformers in the box. Since I have 110V in the box, this should be easy.
Just wondering if you think this is a good idea, and would meet code. I like to do everything to code, or better.
This is the box:
http://www.homedepot.com/h_d1/N-5yc1...1#.UFdvM67TfKE
garya505 is offline   Reply With Quote
Old 09-18-2012, 01:31 PM   #2
Julius793's Avatar
Code wise it's not an issue keep in mind transformers give off heat.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Voltage Detector Affected by Snow? Arnold Ziffel Electrical 1 02-01-2012 09:56 PM
What is causing a low voltage in my ceiling fan/light? rookies5 Electrical 12 01-25-2012 06:18 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 10:31 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
