Old 10-15-2010, 10:41 PM   #1
Low voltage transformers
Does a 120v to 12v 600w low voltage transformer use the same amount of KWPH regardless if there is lights hooked up to it or not?
I ask because I am looking at the option of buying 12v rope lighting vs. 120v.
I have a 600 watt transformer from Home Depot that I'd like to use and keep everything on the 12v system.
I just dont want to power up a 600 watt transformer to only use less than 100 watts.
robbie59 is offline   Reply With Quote
Old 10-15-2010, 10:52 PM   #2
nap
You talking to me?
nap's Avatar
no. there is a very low level of consumption of power with no load on the secondary of the transformer.
Other than those losses, the power input is directly proportional to the power output.
Old 10-15-2010, 10:58 PM   #3
So that hummmming noise is not 600 watts of power getting sucked out of my electric bill? Only draws measurable power if I have lights hooked up to the line right?
Old 10-15-2010, 11:10 PM   #4
nap
You talking to me?
nap's Avatar
the power is measurable but it is only a fraction (small fraction) of the power that can be transferred through the transformer.
You can always put a switch on the line (house voltage) side of the transformer so there are no losses when not being used at all.
Old 10-15-2010, 11:13 PM   #5
Thanks, I have a switch but I was curious to know if I was using too big of a transformer to power a small amount of lights. If the draw is the same as the consumption of watts per light, Im ok with that
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 12:03 PM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 08:44 PM
voltage issues assosiated with banked generator transformers? vaddeboina Off Topic 3 03-11-2010 01:26 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
