Low Voltage Transformer - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 10:13 AM   #16
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by hotrod351
sorry, i was wrong, it happens, even to the best. your right no call for how i reacted to you trying to help. the transformer is 12 VAC 40 watt. now what to do. i have the three 10 watt 12 VDC transformers that came with the kits but hate to wire them all together, the light are all wired together. now i have seen a lot of led landscape lights that run off 12 VDC and 12 VAC. has to be a easier way of doing it.
Lmao!
Never seen a better example of " foot in mouth" syndrome!
sublime2 is offline   Reply With Quote
Old 09-17-2012, 10:31 AM   #17
Rewards Points: 850
now you can see why i said what i said. i admit i made a mistake and you have to jump right in with a smart remark. gee guess your just like me. now whos laughing there ass off.
hotrod351 is offline   Reply With Quote
Old 09-17-2012, 11:38 AM   #18
Oso954's Avatar
Rewards Points: 1,120
Either one of these would work.
http://www.actionlighting.com/ul-lis...r-supply-each/
http://www.trcelectronics.com/Meanwell/eln-60-12.shtml
It's is get a new power pack, or rewire to split the load among the 10 watt transformers you have. Do not attempt to tie the transformers together.
My understanding is that the 0.375 watt bulb (700041) is no longer being made and they are replacing it with the 700044 0.5 watt bulb. So, I would use the 0.5 watt number for planning purposes.
Oso954 is online now   Reply With Quote
Low voltage landscape wiring: Does the wire need to return to the transformer? dgary123 Electrical 7 08-14-2012 10:20 PM
Voltage Detector Affected by Snow? Arnold Ziffel Electrical 1 02-01-2012 09:56 PM
Help - can't find the correct low voltage lighting transformer Sherm Electrical 3 03-24-2011 09:21 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
