Low Voltage Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 11:09 PM   #1
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Is there any reason i can't (or shouldn't) use a regular "houshold type light switch" to control 12v LED lights in my shed. Gonna throw a solar panel on the roof, a battery and controler inside, and wanted to wire up some LEDS inside. I was going to go buy a couple toggle switches, then it dawned on me that I have a bunch of 120v light switches and boxes, why not just use those. am i missing anything?
Mr Chips is offline   Reply With Quote
Old 08-08-2009, 06:04 AM   #2
dSilanskas's Avatar
You can use a regular switch. You don't need anything special
dSilanskas is offline   Reply With Quote
Old 08-08-2009, 11:20 AM   #3
If you do have a problem later on, it could be because the low LED current doesn't cause enough arcing to clean these 15A-rated-switch-contacts, as they are when switching normal household loads.
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
Old 08-08-2009, 03:16 PM   #4
dSilanskas's Avatar
You wont have an issue with it. We use them all the time don't worry about it
Low Voltage Light Switches...40 year old house derekspudich Electrical 28 08-22-2011 12:34 AM
3-way illuminated switch - voltage present ktulu05 Electrical 18 11-29-2009 04:01 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
