Low Voltage Repair - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 07:19 PM   #1
Rewards Points: 260
Low voltage repair
What is the best way to repair low voltage wiring underground (butt connectors, wire nuts, heat shrink)? The wire is for low voltage landscape lighting.
bluefitness is offline   Reply With Quote
Old 11-30-2008, 07:54 PM   #2
Rewards Points: 2,350
Low voltage repair
Splice kits are available for underground splicing. These usually consist of set-screw lugs and heat shrink. For low-voltage, I don't see why butt splices and heat shrink wouldn't work. Maybe even a dose of silicone after it is heat shrinked.
Old 11-30-2008, 07:58 PM   #3
Electrical Contractor
kbsparky's Avatar
Low voltage repair
Use standard wire-nuts, and then fill with hot-glue ...
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
