-   -   Low voltage repair (http://www.diychatroom.com/f18/low-voltage-repair-32894/)
bluefitness 11-30-2008 07:19 PM
Low voltage repair
What is the best way to repair low voltage wiring underground (butt connectors, wire nuts, heat shrink)? The wire is for low voltage landscape lighting.
InPhase277 11-30-2008 07:54 PM
Splice kits are available for underground splicing. These usually consist of set-screw lugs and heat shrink. For low-voltage, I don't see why butt splices and heat shrink wouldn't work. Maybe even a dose of silicone after it is heat shrinked.
kbsparky 11-30-2008 07:58 PM
Use standard wire-nuts, and then fill with hot-glue ... :whistling2:
