Low Voltage Recessed Lights - Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 02:19 PM   #1
Rewards Points: 172
Low voltage Recessed Lights - Wiring
Hello:
I was replacing some old lights in a bedroom with Nicor Low Voltage IC Boxes-NA14102A. The circuit it is on is 20Amp. When I opened up the LV housing I noticed it has quick connectors. My question is, do I attach the 12/2 wire right in to the quick connectors or do I need to cut them off and use a cap? Also, for multiple boxes can I just connect the next feed into the quick connect? Or am I missing something?
Thanks for the help!
zephed666 is offline   Reply With Quote
Old 03-28-2011, 02:39 PM   #2
Originally Posted by zephed666 View Post
Hello:
I am not familar with those boxes, however, you need to read the instructions that came with the box or the specs sticker on the box. Many "quick" connections are only rated for 14 guage or smaller. If they are rated for 12 guage, then you can daisy chain them without any trouble.
bhennon is offline   Reply With Quote
Old 03-28-2011, 03:41 PM   #3
Rewards Points: 172
there were no instructions. that is why I asked and added the model number...
Old 03-28-2011, 03:52 PM   #4
Looks like that model uses "IDEAL" push in wire connectors. Take a look at their website and see if your connector is shown there and look up the appropriate spec sheet.
http://www.idealindustries.com/prodDetail.do?prodId=in-sure&div=0&l1=push-in
looks like most of them are 12-22 gauge wire so you should be ok.
Old 03-28-2011, 04:01 PM   #5
Rewards Points: 172
Thanks! I didn't think to look up the connector, have been trying to look up the can and found nothing...
Never used the quick connects either. Just wanted to make sure it was acceptableto daisy chain...
Lights flickering, voltage fluctuations throughout house jaytorr Electrical 7 11-02-2010 01:21 PM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 05:40 PM
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 01:58 AM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-09-2010 11:27 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
