Low Voltage Power Interuptor - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 08:32 PM   #1
Low Voltage Power interuptor
I have a security camera in my barn that I would like to have turn off durning certain hours.
Is there any recommendations as to how I could accomplish this? The power and video are ran to the camera from the power supply via cat 5 and is low voltage.
Suggestions?
I was thinking some sort of interupter switch that I could have plugged into a light timer. Would that work? any ideas how to get this interupter?
mntnvew is offline   Reply With Quote
Old 01-31-2011, 08:40 PM   #2
Electrical Supplier
Rewards Points: 150
Relay system for the LV switching, and a timer for the signal.....
Some timers have a built in relay system so that they are powered by line voltage, but switch anything up to 240 volts.....
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-31-2011, 08:43 PM   #3
Got any links to any of these relays (you're speaking to a novice )?
Old 01-31-2011, 09:01 PM   #4
joed's Avatar
Rewards Points: 11,998
Put a timer on the low voltage power supply 120 volt input. 120 volt timer are common.
Old 01-31-2011, 09:33 PM   #5
Unfortunately this is not an option as I only want 1 camera to turn off and all the cameras are powered from a single source.
Old 01-31-2011, 09:40 PM   #6
Electrical Supplier
Rewards Points: 150
whats the voltage? 24vdc by chance?
Old 01-31-2011, 09:49 PM   #7
Electrical Supplier
Rewards Points: 150
This is your easiest option IMO. And cheapest.
You are going to have to splice/interrupt the circuit regardless.
I say put it on its own power feed, get a 24 hour timer and transformer. Wire the transformer to the switched feed from the timer....
Old 01-31-2011, 09:50 PM   #8
12vdc
Old 01-31-2011, 10:45 PM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,898
Suggestions?
The easiest solution will be to re-think your requirements so you don't have to do this the way you are asking about. What are you ultimately trying to accomplish? Why does this one camera have to operate only some of the time?
mpoulton is offline   Reply With Quote
Old 02-01-2011, 12:16 PM   #10
Why is really irrelevant.
The fact of the matter is that I have to accomplish this... anyone have any ideas other than the ones previously discussed?
THANKS!
Old 02-02-2011, 02:02 AM   #11
THANKS!
No, I don't. Without better information on your hardware and your goals, I have no further input other than to reiterate my previous statement: there will almost certainly be a better, simpler, cheaper, easier way to solve your problem.
Old 02-02-2011, 02:38 PM   #12
1. buy a 12V DC programmable timer, such as this one: http://www.brazix.com/prodfly.asp?It...FYrt7QodMh2vVg
2. determine which conductors in the CAT 5 carry the voltage (google or experiment)
3. build a short adapter cable with the power conductors rerouted through the timer
thadsaab is offline   Reply With Quote
Why do differently gauged power cords all rank at the same amp and voltage use? Freshbrood Electrical 6 01-08-2011 08:36 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
power to "half" the house dogvila Electrical 8 07-13-2010 10:04 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
