Low Voltage Motion Sensor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 06:54 PM   #1
Low voltage motion sensor
I'm trying to figure out how to wire a motion sensor into a 12 volt landscape lighting system. I believe red will go to one of the wires to the light fixture and white will go to the other wire from the light fixture, so where does the black go? Somewhere on the transformer?
mattvog is offline   Reply With Quote
Old 09-10-2010, 06:19 AM   #2
What kind of motion sensor? One intended to be powered by 120VAC? If so, then it probably won't work being powered by a 12V lighting system. Otherwise, please describe.
light fixture
??? What light fixture? I thought you were trying to use this with a landscape lighting system? Are you trying to use this motion sensor to control a single fixture of your landscape lighting system?
oberkc is offline   Reply With Quote
Tags
low voltage motion sensor
Cooper Motion Sensor Help needed please scoops Electrical 3 02-23-2012 10:39 PM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-09-2010 11:27 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
Wiring Motion Sensor Electronic Lighting Switch consultant Electrical 2 03-07-2010 07:19 PM
What type of wire to connect motion sensor to light? beezlebub03 Electrical 1 05-31-2008 01:16 PM
