Old 11-24-2008, 08:27 AM   #1
Low Voltage = Low Bills?
The trend is for spot lights, lots of them.
Running on lower voltage (50v) means they draw lower current. Correct?
Then a 20w spot is cheaper to run than a normal 20w bulb. Would that be 4/5 times cheaper or watt? Parden the pun.
uglybains is offline   Reply With Quote
Old 11-24-2008, 08:36 AM   #2
Not exactly, that is why the power company uses 14,000 volts. Usually its higher volts= lower current.
rgsgww is offline   Reply With Quote
Old 11-24-2008, 08:37 AM   #3
DIYer
20 watts is 20 watts it doesn't matter what voltage it's at.
Low voltage lights have the additional disadvantage of inefficiency in the transformer/power supply, plus also it's harder to design low voltage bulbs that are as efficient and last as long.
20 watts at 50 volts is 400 milliamps. 20 watts at 120 volts is 160 milliamps. Do you understand now?
Gigs is offline   Reply With Quote
Old 11-24-2008, 09:18 AM   #4
Sort of. thinking back to my college days
I guess pot lights are out as I don't trust the person under it to switch off when not in the room.
Old 11-24-2008, 10:18 AM   #5
DIYer
The only way it'll be cheaper is if you use 120v bulbs at 50v, then they do use less power. But if you use a 50v bulb at 50v then it uses its normal wattage.
Old 11-24-2008, 11:39 AM   #6
Use 120V LED lights if you want to save on your electric bill...
Google LED lights...
http://www.google.com/search?num=20&...ed+lights+cart
Billy_Bob is offline   Reply With Quote
Tags
low voltage, spots
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 02:50 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
