Low-voltage LEDs Setup - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 12:19 PM   #1
Rewards Points: 12
This is a followup to a thread I started a few months back:
LED Strip Wiring Questions
I'm just about done and things are looking pretty good, but I just want to make sure I'm not doing anything inherently dangerous/against code.
I'm using a spare computer PSU to supply 12v power (which I believe is 17amps max on the 12v) which connects to the LED controller unit. The controller has connections for 9 RGB light branches (so 4-wires x 9) and has a max load of 15amps. The PSU and controller unit are in a utility closet in the basement. Currently I have 6 branches done and it's putting me around 7.5amps. Out of the controller for each branch I'm using 18AWG In-Wall rated cables (http://www.monoprice.com/products/pr...seq=1&format=2). The 18AWG wires goes out of the utility closet and into the drop ceiling, my average run is around 25ft. I then connect the 18AWG to the RGB ribbon which is 22AWG via regular wire nuts which I just have over the ceiling tiles. The highest run is around 2.5 amps, but most are around 1.5 amp or less.
Any red flags here? Are the wire nuts ok? Obviously you can't just have wire nuts for line voltage, but I'm not sure what the rules are for low voltage.
khargy is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 11:03 AM
New DIY LED Setup -- Input Appreciated jonnybravo22 Electrical 2 11-16-2009 07:00 AM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
