Old 08-14-2012, 09:58 PM   #1
Question
Low voltage landscape wiring: Does the wire need to return to the transformer?
Hi there,
I've been looking at tutorials and such but I can't seem to find a solid answer.
I've bought a low voltage outdoor transformer (120W magnetic power pack from Lowes), and I don't know whether the landscape cable needs to go from the transformer, to the lights, and then back to the transformer? Or whether it can just end at the last light?
Any help would be greatly appreciated! I know this might sound like a stupid question, but I don't want to mess up!
Daniel
dgary123 is offline   Reply With Quote
Old 08-14-2012, 10:23 PM   #2
Licensed Electrician
k_buz's Avatar
Ends at the last light.
Location...Location...Location
k_buz is online now   Reply With Quote
Old 08-14-2012, 10:32 PM   #3
E2 Electrician
stickboy1375's Avatar
Depends on the load, coming back to the transformer lowers the voltage drop, but running individual homeruns works also..
it all depends on the load vs distance.
Old 08-14-2012, 10:42 PM   #4
Oh okay thanks. In my case, I will have 8 7W deck lights connected to a wire that's about 55' long. How does that work?
Old 08-14-2012, 10:49 PM   #5
Missouri Bound's Avatar
That will work just fine....What is the wattage of your xformer?
Do you want it your way or the right way?
Old 08-14-2012, 10:49 PM   #6
E2 Electrician
you will be fine, but I would split the load in half to ensure proper voltage and equal light output.
Old 08-14-2012, 11:17 PM   #7
What do you mean? I calculated the voltage drop to be something less than 5% (I forget the exact number) is that too much? How would I split it?
Old 08-14-2012, 11:20 PM   #8
E2 Electrician
you run two wires, one wire supplies half the lights, the other wire supplies the other half... this halfs the total load and the voltage drop.
You are probably fine with what you have, but this will ensure future add ons and stability of existing loads.
Tags
landscape, landscape wiring, lighting, low voltage, transformer
wiring a whirlpool cooktop davidtyson Electrical 8 06-17-2012 02:58 AM
Control board wiring, HQ1011927HW transformer wire needs attaching xlr8-to-xl HVAC 2 06-03-2012 09:24 PM
Low voltage interior wiring systems WillK Electrical 0 01-03-2011 09:14 PM
Which low voltage wire scozzer Electrical 2 02-18-2007 11:56 PM
