-   -   Low voltage landscape wiring: Does the wire need to return to the transformer? (http://www.diychatroom.com/f18/low-voltage-landscape-wiring-does-wire-need-return-transformer-153717/)
dgary123 08-14-2012 08:58 PM
Hi there,
I've been looking at tutorials and such but I can't seem to find a solid answer.
I've bought a low voltage outdoor transformer (120W magnetic power pack from Lowes), and I don't know whether the landscape cable needs to go from the transformer, to the lights, and then back to the transformer? Or whether it can just end at the last light?
Any help would be greatly appreciated! I know this might sound like a stupid question, but I don't want to mess up!
Daniel
k_buz 08-14-2012 09:23 PM
Ends at the last light.
stickboy1375 08-14-2012 09:32 PM
12 Attachment(s)
Depends on the load, coming back to the transformer lowers the voltage drop, but running individual homeruns works also..
it all depends on the load vs distance.
dgary123 08-14-2012 09:42 PM
Oh okay thanks. In my case, I will have 8 7W deck lights connected to a wire that's about 55' long. How does that work?
Missouri Bound 08-14-2012 09:49 PM
That will work just fine....What is the wattage of your xformer?
stickboy1375 08-14-2012 09:49 PM
12 Attachment(s)
you will be fine, but I would split the load in half to ensure proper voltage and equal light output.
dgary123 08-14-2012 10:17 PM
What do you mean? I calculated the voltage drop to be something less than 5% (I forget the exact number) is that too much? How would I split it?
stickboy1375 08-14-2012 10:20 PM
12 Attachment(s)
you run two wires, one wire supplies half the lights, the other wire supplies the other half... this halfs the total load and the voltage drop.
You are probably fine with what you have, but this will ensure future add ons and stability of existing loads.
