Low Voltage Landscape Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 10:00 PM   #1
I have eight low voltage landscape lights, three path lights down each side of the driveway with a post light at the end of the drive. One side was dimmer than the other, and I suspected it was because of the run the wire had to make to get to the other side of the driveway. So, a second transformer was installed to power the far side. Still not quite equal. The path lights are now in fairly rough shape and we are planning to replace them. My thought was that buying LED path lights would use less energy, therefore not causing either side to dim due to lack of power at the end of the run. Am I right to think this might help? Also, I already cut the original transformer's load in half, since it was initially intended to power all eight lights. Now I'm significantly cutting the power needed from the transformer again down to four small LED lights drawing only 1.5 watts each (maybe a couple more watts in the post light if i can find a way to retrofit it). And the new transformer would also have this small load as well. Will this small of a load cause any issues? Thanks!!
tbbuhner is offline   Reply With Quote
Old 04-27-2013, 10:20 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
None what so ever.....a very wise move.
Additionally, those LED lights will last a LOT longer.
If your looking for LED lights, may I suggest SuperBrightLED as a source for all types (including hard to find) LED's?
Old 04-27-2013, 10:28 PM   #3
Rewards Points: 156
Your thinking is perfect...the LED lights will cause less voltage drop and you can run more on the lines. One bit of advice though is to get voltage regulated transformers. LED lights don't take too kindly to over-voltage conditions and spikes and such. They will burn out quickly if they don't get clean power.
av-geek is offline   Reply With Quote
Old 04-27-2013, 10:56 PM   #4
Sounds good, and thanks for the replies! I thought I heard somewhere that significantly under loading a transformer could be bad or unsafe, but I might have misunderstood since I'm not super knowledgeable in that area!
Old 04-28-2013, 12:07 AM   #5
dmxtothemax's Avatar
Rewards Points: 5,182
Your problem was most likely caused by -
1 - a bad connecttion somewhere,
2 - a faulty cable run.
3 - Wrong size cable.
Remember at low voltage, it only takes a little
extra resistance (bad join) and you can lose a
lot of power.
Check and double check all joints and cables.
dmxtothemax is online now   Reply With Quote
Old 04-28-2013, 03:13 AM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
lot of power.
I'm guessing the problem was just a poorly designed wiring layout, you have to take extra care with voltage drop when it comes to low voltage landscape lights.
The Following User Says Thank You to stickboy1375 For This Useful Post:
daveplot (04-28-2013)
Low voltage lighting MikeVila Gardening Forum 1 06-18-2012 09:07 PM
Homemade Landscape Lighting Randell Tarin Landscaping & Lawn Care 18 02-28-2012 12:31 PM
landscape lighting wire ? voltage drop daddyt Electrical 11 06-26-2011 11:51 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
