Old 10-19-2012, 12:16 AM   #1
Low voltage GE electric Relay system
I have the low voltage electric system common in houses built in the 50s/60s. A royal pain the rear - no clue why they did this
Anyway - my bathrooms fans have both stopped working (and heated lamps) and ive traced the culprit back to the Relay Box in the crawl space - any idea how to proceed and find out if its a dodgy relay ?
grahamswilliams is offline   Reply With Quote
Old 10-19-2012, 06:15 AM   #2
Electrical Contractor
kbsparky's Avatar
First, you should troubleshoot the switches and wiring to ensure that the relay is getting a signal.
If the control voltage is present, and the relay is inoperative, then replace the relay.
You could swap the relay with another working one to eliminate that possibility if you don't want to put out the cost of a new unit....
-KB
Upgrades for my old electric furnace? alochin HVAC 6 09-11-2011 07:09 PM
fluorescent light on a low voltage switching system? lulufarm Electrical 1 05-13-2011 01:00 PM
Which type of low voltage system do I have? mrominger Electrical 1 04-25-2011 05:55 PM
Electric Run, Voltage Drop Issues. Eventual upgrade of system this year. lawnphysics Electrical 4 04-06-2011 07:24 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
