Low Voltage Dimmer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2009, 04:37 PM   #1
Low Voltage dimmer
I've just installed a hampton bay track system in my home. I used 4 low voltage lights. I think the have their own transformer.
here's the link
http://www.homedepot.com/webapp/wcs/...401+501401+904
my question is, I'd like to install a dimmer and the specs say use an ELECTRIC low voltage dimmer, I got a crappy one at HD and it didn't work! will it not work cause the wiring is old knob and tube with no neutral or ground? Any suggestions?
nolatune is offline   Reply With Quote
Old 02-18-2009, 09:38 PM   #2
Electrician
If you have knob and tube style wiring in your house then there should be a neutral and a hot wire ran side by side. The absents of a ground is an unsettling idea, grounds are installed for safety. I reviewed the HD web site and it doesn't state the voltage of your lights but from the accessory's shown I tend to believe that this isn't low voltage but in fact 120v. where are the transformers located (maybe in each light). if that's the case you should get the proper dimmer for that system from the manufacturer. transformers by code must be grounded, if the transformers are in each track head then they pickup the ground there. make sure that connect a ground to this track. If any part of this system is electronic the absents of a ground would definitely affect it.
spark-451 is offline   Reply With Quote
Blowing Dimmer and Voltage Variation briggss` Electrical 19 02-17-2009 04:41 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
dimmer switch circuit wiring stan_d_bballman Electrical 2 11-17-2007 12:44 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
