Low Voltage Code - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 04:32 PM   #1
Rewards Points: 278
Low voltage code
Hi, I wanted to know what are the rules for wiring low voltage?
I am using a plug in transformer to get 12VDC and then running the low voltage wires to Low Voltage MR16 recessed halogen housings. I know some guidelines to wire gauges from working on cars, but what are the rules when wiring lighting like this at home? Can you use speaker wires of the correct gauge. Can you just use 12VDC switches from radio shack?
DIYGST is offline   Reply With Quote
Old 01-06-2009, 05:02 PM   #2
Electrician
Article 411 of the NEC is a good place to start.
chris75 is offline   Reply With Quote
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Voltage Drop Issues sushiboy Electrical 12 04-03-2008 10:01 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 10:38 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
